ControlLogix 5555 redunadancy failure
clementaliu
May 2006
Lagos
I have a redundant ControlLogix 5555 with two I/O racks. The redundant SRM was disqualified and have not been able to get it backup running. I check the individual modules which consist of 3 controlnet cards, 1 processor and redundancy module and they are all healthy apart from the processor that had a minor recoverable fault which i could not clear but i replaced it with a new module. the firmware for the new module has been updated. I still have the problem.
When i boot up the rack the network leds for the controlnet cards come up solid green while the OK led flashes green.
The processor ok led is solid green
The redundancy module ok led is solid green. and it displays Disqualified secondary.
In the Rslinx SRM configuration tool for the secondary the synchronisation tab the only option available to me is the "become primary" all others are greyed out.
Is there anyone that can suggest anything t me.
Thank you
I still have three applications using the 1756- L55 Processors on some new clients and in the need copy of Firmware ControlLogix 5555 1756-L55...
4,235
The only thing I've ever used a Logix controller serial port is for configuration purposes. I have never seen that port utilized for data...
2,665
Can anyone help shed some light on this. ControlLogix5555 was being edited online, with pending edits, when we lost comms from the laptop, then...
1,315
Hello, I want to use Advantech Webaccess software as HMI and connect it to Allen Bradley ControlLogix 5555 Processor (1756-L55) through Ethernet...
2,926
Hi, I need to purchase a software for HMI which will communicate with Allen Bradly ControlLogix 5555(1756-L55) PLC through Ethernet Module...
4,711
