jets
I am working with a Mitsubishi VFD that has RS485-4 communications. Another servo in the system has RS485-2 and Ethernet.
My communication need for the Mits VFD is only to write parameters to the VFD like speed or torque reference and maybe jog speed reference.
I know this subject must have been beaten to death over the years. But what do you do in this situation us a converter?
Is there a wiring way to write only to RS485-4 wire from RS485-2 wire?
On my HMI I have many options. The HMI has RS485-4 or RS485-2 (but not both at same time), a separate RS232 port along with Ethernet and USB host.
What is the easiest way with least amount of additional hardware to communicate with the RS485-4 port? I guess I could look at getting an option card to give the Mits FR-V500 ethernet and then I could just use all ethernet.
TIA
TIA
