about RTU
abdallh
Dec 2012
sudan
HI every one we treat in our company with RTU and i find in RTU cabinet (alstom ISTAT 300) and i search in alstom web about ISTAT 300 and i find its transducer
My question is why we use transducer in RTU and for what
not :-
Our main job in the company is distribute electricity (transfer from 33kv to 11kv )
we use RTU to collect data from switch gear and send it to control center
:confused::confused::confused::confused:
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
45
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
204
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
239
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
108
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
474
