Firmware on Tia portal download
Cjohan
Sep 2020
Peterborough
31
Hi
If i download to a new PLC with firmware V4.4 and i use Tia portal v11 to make the download will it downgrade the firmware of the new PLC or not
Hi
TIA Portal does not automatically change PLC firmware, although it is possible. Generally, as long as the PLC FW is newer, it will work fine without any change: V2.6 project can be downloaded into v2.8 S71500 with no issues.
HOWEVER, for security reasons, they had to break compatibility when the S71200s went from V3 to V4 FW. I think the V4 CPUs require at least V13 to be used, but I could be wrong on the Step 7 version.
I believe the difference is 64bit and 32bit coding. Changed at TIA V15.
Hi, I have an XB208 which has V4.3 firmware on the device. I only have V3.0 showing up on my TIA portal (V15). Can anyone share how I get the...
1,311
HI all! New to Siemens and was wondering when adding a drive to a project is there a way to select the Firmware of the drive when adding it? I...
4,347
I have a project that was converted to v14 of portal. I'm trying to get online with the PLC (S7-1214 v2.2.0 firmware). Portal is saying that I...
3,792
I'm new to TIA Portal still and am trying to retrieve a project, however when I do, I get this error. I had more updates required, but I was able...
5,785
I have a customer that has purchased a trainer and has a couple question that I do not know the answer to but thinking that someone here may...
3,477
