Tool f/test/verification of EtherNet/IP networks vulnerability against DoS attacks
AlfredoQuintero
Feb 2015
Yokohama
1,548
Hello:
Does any body have experience with tools to simulate DoS attacks, especially attacks which can exploit typical vulnerabilities of EtherNet/IP devices?
Will be grateful for recommendations, whether it is free software or paid software.
Many years ago the National Institute of Standards and Technology (NIST) started a project with ODVA which seems to have stalled as the last delivery of this tool which is free of charge, was provided in 2009, but I find this software crashes in Windows 10. Cannot find a newer version. (By the way if someone has experience with this tool and can give me a hint such as "run it in Windows XP", I am willing to do this setup just to get it working).
Thanks for reading.
Ethernet/IP is an unencrypted protocol and without intrinsic security.
Therefore it should not be open to connections from the WAN and it is usually not exposed to DoS attacks ... except if the attacker is on the same plant/LAN :eek:
Even if it is unencrypted, there should some robust mechanism to ensure that the Ethernet/IP data has priority over other data.
It may not be a hacker, but for example a faulty device that spams the network with packets.
Exactly. For example, for Profinet devices there is a test called Netload test. It consists of a Linux packet generator that sends bursts of ARP, DCP, IGMP and what not, to see if the device crashes. Another test is done while talking to the PLC and the PLC has a program that logs communication error, if the device stops communicating during the "normal communication" test the device fails the test. The "Faulty communication" sends so much data that if you try to capture with Wireshark the PC stops responding to commands so one has to use TSHARK to capture data. It is insane, like 10 packets per millisec. So yes, EtherNet/IP networks should not be accessible from outside the industrial control network environment, but nonetheless, security is a concern, as you can read from link below.
https://us-cert.cisa.gov/ics/alerts/ICS-ALERT-12-046-01A
Why not use the Profinet tool with Ethernet/IP ? Should be the same.
Hello. Yes, this is my plan B. I am used to the Profinet test and I can set it up in short time. This test sends bursts of ARP, IGMP and other traffic that can push the EtherNet/IP adapter to its limits. If there is something very wrong it should surface, although it may not be the most accurate test, it is better than nothing. If I do not find anything more suitable, I will use this test. Thanks for the suggestion.
Can anyone recommend a profibus test tool now that the Siemens BT200 has been discontinued?
1,591
Can somebody share the AutroSafe configuration Tool C4.11.4 Thank you
108
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
129
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
345
Hello everyone, I'm having trouble downloading a file to a omron nt11 PT. I am able to upload from 2 other PT's but am unable to download...
220
