plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 12th, 2011, 10:24 AM   #1
mdelyser
United States
mdelyser is offline
logix5000 issue
I am using logix 5000 with an HMI that is unable to read ALIAS tags, User defined data types or an INT down to BIT level. Is there a way to map an INT or DINT to a BOOL array? Suggestions? Thanks.
Old April 12th, 2011, 11:12 AM   #2
rdrast
United States
rdrast is offline
rdrast's Avatar
Hrm... just maybe, could'ya possibly, if'n it tisn't too much trouble, just add a few teensy details?
If you'd rather not, I'll just say that my HMI works fine with my processor, so you really don't have a problem.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old April 12th, 2011, 11:26 AM   #3
mdelyser
United States
mdelyser is offline
Sorry about that...
I am using a Maple Systems HMI with a CLX L61 rev 18 processor
My company's standard code uses Alias tags to read down to bit level of an INT word for a jam condition in the system. The HMI cannot read this Alias tag or the bit level of the INT word, the HMI can only see the INT word itself and read its overall value. I am hoping to find a way to map the bit level of the INT word into a BOOL array that the HMI can read. I am just trying to find a better way than having a rung of code for each bit mapped over. The final BOOL Bit is to trigger a specific alarm message in the HMI.
I hope gives you some more info..... Thanks for the help
Old April 12th, 2011, 11:38 AM   #4
bigbuckaroo
United States
bigbuckaroo is offline
Not sure which Maple Systems unit you are using but a couple of weeks ago I recieved an email from them regarding an update for EZWare 5000 to version 4.40. One of the updates had to do with a "User defined data type editor" that is billed as "A tool to allow the Maple Graphic HMI to interface with Allen Bradley User Defined Data Types". Hopes this helps
Old April 12th, 2011, 11:41 AM   #5
bigbuckaroo
United States
Why in my response does the word quote show up instead of the symbol like I typed it?
Old April 13th, 2011, 05:26 AM   #6
rdrast
United States
rdrast is offline
rdrast's Avatar
Quote:
Perhaps because you didn't use the right tags?
Open tag: [_quote_]
Close tag: [_/quote_]
Don't include the underscores.
__________________
Old April 14th, 2011, 05:17 PM   #7
daba
United Kingdom
daba is offline
daba's Avatar
Best way is to use the "Advanced" Editor, select any text you want as a quote, and hit the "Wrap [quote] tags around selected text" button.... see pic
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old April 14th, 2011, 05:58 PM   #8
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
No,he's referring to quotes like around your word Advacnced. They got changed to the HTML representation of them.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old April 14th, 2011, 06:32 PM   #9
TConnolly
United States
TConnolly is offline
TConnolly's Avatar
Does your HMI support expressions? If so you can use a bitwise AND to determine the state of any bit in an integer.
(TagName AND 1) will tell you if Tagname.0 is set.
(Tagname AND 2) will tell you if Tagname.1 is set.
(Tagname AND 4) will tell you if Tagname.2 is set.
(Tagname AND 8) will tell you if Tagname.3 is set.
etc.
__________________
True craftsmanship is only one more power tool away.
That's the beauty of processors, they don't have emotions they just run code - The PLC Kid.
Old April 15th, 2011, 03:29 PM   #10
davidg68124
United States
davidg68124 is offline
davidg68124's Avatar
Wow, guys, have you forgotten the feature in Logix5000 where you can dedicate items to legacy addressing?
Under the Logic Drop down menu, select Map PLC/SLC Messages...
There you will assign your booleans array to the right file for a slc/plc.
David
__________________
The PRICE of FREEDOM is not FREE! My son is now a United States Marine and I could not be more proud of what he and others will do to protect our freedoms here at home.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Rs logix5000 addressing issue anstee33 LIVE PLC Questions And Answers 13 October 18th, 2010 01:23 AM
Mitsubishi GOT issue (long winded) Killercal LIVE PLC Questions And Answers 4 August 18th, 2009 07:28 PM
Logix5000 indirect issue johnfarrugi LIVE PLC Questions And Answers 4 May 14th, 2008 11:42 AM
AB 1734-AENT POint IO issue ettikudiappan LIVE PLC Questions And Answers 0 July 17th, 2007 09:42 PM
+ or - for Logix5000? Rob D. LIVE PLC Questions And Answers 26 May 19th, 2006 05:06 PM
