Simatic OP 177 string tags
Polle
Oct 2004
29
Here's my problem:
i made an internal tag in WinCCflex, datatype String.
I put this tag in a few I/O fields, all have string length 20.
When I enter a text in the I/O field in runtime, only the first ten characters appear in the tag.
Looks kinda weird to me.
Polle
String length
While I haven't used WinCC Flexible myself, my imidiate reaction was that you had perhaps limited the length on the tag to 10 chars?
So that even if the I/O field itself can hold 20 characters, the actual string can perhaps only hold 10? (maybe a default size for string type internal tags in WinCC Flex?)
Try checking the properties of the tag, but like I said, I never worked with Flexible, and have no developer licence to any WinCC at my current work.
Itka,
I was thinking in that direction too, but i cannot find a way to set the length.
Polle
Communication-->Tags mark your tag and choose general under settings you define the tag length.
Bratt,
I didn't see the properties window under the tag list like i see in your example, but now i know what to look for, tomorrow morning.
Thanks for helping me out!
PoL
Hi, We have a simatic Touch Panel OP 177B which is fault. For past 6 months we have been using a mouse to start the conveyors not a fingure...
2,292
We have updated s5 to s7200 ,just downloading to the screen TP177 micro using win flex 2005. This will not communicate as the download for the...
5,299
Hello. How to protect access to some views : Hardware : Siemens SIMATIC TP 177micro Software : SIMATIC WinCC flexible Micro...
3,617
Hi all. I am using a TP177 Micro and would like to know if there is anyway in which I can change the current active screen from the PLC. I am...
5,093
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
79
