Schneider electric quantum series hotstandby plc 140cpu67160
pravingk
Aug 2014
akola, maharashtra
Dear sir,
I've Schneider electric Quantum series hotstandby plc 140cpu67160 and unitypro XL 2.3V and OS loader 2.31V.I've problem that when power failure is occured & there is no battery backup my plc is got off,when power supply is restored primary plc fails and goes in fault mode also ethernet module 140noe77101 goes in fault mode due to this switchover to secondary plc and run as primary.My previous primary plc cpu is damaged in power failure, we replace faulty plc cpu with new cpu of same model, but having OS Loader 2.2V so problem facing of incompability of plc cpu and not allowing to download plc program and connect the plc.So please suggest me the proper solution and procedure to connect plc secondary plc cpu and download the program.
PRAVIN
Hi, I have a Modbus/TCP operational network. Last week a NOE 771 01 on one of my Hot Standby PLC System, Standby PLC stopped communicating. On...
1,883
I am hoping that someone here is familiar with adding a Generic module specifically a mettle Toledo IND 131 module to a Schneider Electric Quantum...
3,720
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
230
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
116
Hello, Does anyone know why this AMO 0410 or AMO0410 module flashing all 4 channels with green LED and the IO LED on the display is solid red ...
485
