Factory Talk View Studio v13 ME error - Cannot Create OLE Prop Page
JGLipo
Feb 2023
MI
Hello all. Hoping someone could give me a lead to follow. I'm currently using Factory Talk v13, however it will not allow me to access the "Connections" tabs for OLE's. I am able to go online and see the statuses of the display pages, so that tells me FT knows the proper connections. I'm leaning towards it being an ActiveX issue, since it's just failing to display the Connections Properties. I have reinstalled Factory Talk as well as Factory Talk Service Package as per Rockwell's TechConnect's recommendation, but no luck. I get the same results for both .apa and .mer files. I had no issues with FT prior to 2/7/23, the next day I was unable to view connections. This led me to believe it was related to a windows update, so I uninstalled all windows updates from the previous day. No luck. Can anyone offer any other suggestions?
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
320
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
287
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
589
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
363
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
678
