drbitboy
Wow! what we got here:
Half of those are mine and therefore don't count .
- A plastic ball on plastic channel isn't great, but it's better than cloth
- A more obtuse angle in the channel might help as well,
- or maybe use a piece of PVC pipe as the channel, so there is only one point of contact with a lower loading
[*]Hollow ball acceleration coefficient is 5/3
[*]Solid ball acceleration coefficient is 7/5
[/LIST]
Hey, let's make it interesting: fill the ping pong ball with water; now Navier and Stokes are involved !
Another way to eliminate linkage deadband would be to put the fulcrum at one end instead of in the middle,
can[Hollow ball acceleration coefficient is 5/3 ... Solid ball acceleration coefficient is 7/5't?] you explain?
This should solve the problem of the rod playing, but will make the PID trainer less scientific-like and, as a result, less attractive to potential buyers
I don't know where those acceleration numbers come from.
Are you asking me to show the derivation?
Teaching either how to tune a PID
Yep. Or I it is my poor English I misunderstand “acceleration icient” or something wrong with my math – I don’t get your numbers
getting close now:
[/COLOR]aLinear = g sin(θ) / (1 + 2/3) = 3 g sin(θ) / 5 for spherical shells (ping pong balls)and
aLinear = g sin(θ) / (1 + 2/5) = 5 g sin(θ) / 7 for solid balls
Thanksbut the English idiom is "can you [please] explain?"
I already know what this idiom means :-///Ha ha your English is so much better than my Czech
5.9 and 7 * g * Theta ???
I get the same number as drbitboy, 5.887 for a hollow sphere if I combine all the numbers so 5.887 is just multiplied by the tilt in radians.
Also, since this is two pole system I calculate the Kp and Kd values for the tilt as Kp=6.709 rad/m and Kd = 2.136 rad/(m/s). This places two poles at -2*PI. I could calculate the an integrator gain too but that adds another pole to the closed loop transfer function. I didn't assume any friction. That would decrease the Kd value a bit. Since my simulator doesn't have any noise, I can increase the response but I think in reality that noise will limit to how high the gains can go.
Are we done yet?
5.887 is a factor for a flat surface and not for a 90 degree gutter, but it's not really significant.
can you [please] explain?Arrgh, nice. How did I miss that?
4.2 θ, shell
5.4 θ, solid
