Hey guys, am I over looking something here?
I have my Siemens PLC's (300's) synced with a NTP server. The PLC gets the UTC time from the server. I can then use Siemens block to conver the UTC time to Local time. This local time can be pushed to the HMI but not stored as the system time.
So after syncing:
PLC (diagnostic buffer) = UTC time
HMI (alarm logs) = Local time
Even though it is only 4 to 5 hours different it is a hassle to figure out the corresponding times.
My next step is to setup a linux NTPD server and have it provide the local time instead of the UTC. This way the PLC and HMI times will be in sync.
Any other ideas?
P.S. When I looked on the Siemens forums they showed examples that when you specify your NTP server you could pick your offset e.g. GMT +5, but that isn't an option in my software.
So after syncing:
Any other ideas?
