plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old November 18th, 2009, 06:17 PM   #1
bikerdude
United States
bikerdude is offline
bikerdude's Avatar
FTView ME Numerical Display Issue
I have a PV+ touch only screen supplied by a vendor that has a glitch. I think the P.N.# is 2711P-T7C4 v4 firmware. I am not a PV+ expert by any stretch but I have done a few from scratch & updated a few that vendors have supplied. There is one screen with a numerical display (floating point) that is supposed to display a temperature. The temperature value never updates while the screen is displayed. If you leave the screen & come back the temperature is displayed again with the correct value but the value remains static. I can't figure out what the problem is.
Has anyone seen this before? I cant post the file due to company policy of privacy. The numerical display is a member of a group of objects, would that cause this to happen?
Thanks for any or all ideas
BD
Old November 18th, 2009, 06:50 PM   #2
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
Are you sure it's not a PLC program issue?
One thing we do on occasion is look at the screen number that the user is on and update the tags only when the user initially goes to a specific screen (using a one shot).
Old November 18th, 2009, 06:50 PM   #3
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Is the numeric display an expression, a direct reference tag, or an HMI memory tag ?
Maybe it's a value that is calculated by a macro or some other mechanism only when the Display is opened.
Or maybe the logic in the controller calculates the value once when it sees that you've opened the Display that contains it. The PV+ would have to be using the Global Objects to send the current Display number to the controller.
Old November 18th, 2009, 08:11 PM   #4
bikerdude
United States
bikerdude's Avatar
I looked for macros that are on the "Behavior" tab of the display settings window. There are none in the start or shutdown boxes. It is a direct refrence to a PLC tag (F8:18) I think.
I did not think to look for macros in the "Logic and Control" folder like I should have.
Here is what I did to test the system out.
I was online with the PLC and I looked at the screen, it dispalyed 0.00 which matched the PLC F8:18 value. I edited the PLC rung to disable a move instruction that puts a zero in F8:18 while "Not" in "CIP" mode. Apparently the original programmer didn't want the true temperature displayed unless the machine was in "CIP" mode. Now looking at the PLC data table the F8:18 is 78.9. I walk over to the panelview 40 feet away & the display still shows 0.0. I go the the "Main" screen & then navigate back to the "CIP" screen and the display then shows 78.9 as it should. I walk back to the laptop, remove the recent edit which forces the value back to zero. Walk over to the panelview & the display still reads 78.9. Hmmmm.... Navigate to the "Main" screen & them back to the "CIP" screen & it shows 0.0 as it should.Hmmmm..... it seems that the value is updated on the screen only upon loading.
I am going to look at the PLC program a little closer to see if there are any conditional JSR instructions I may have overlooked.
BD
Old November 18th, 2009, 09:08 PM   #5
Ken Roach
United States
Ken Roach's Avatar
Wierd !
Is it possible that this specific Display has a super-long Update Interval ? I don't know what the maximum update interval is for a PanelView+ Display.
Old November 18th, 2009, 09:17 PM   #6
bikerdude
United States
bikerdude's Avatar
I can't find any problems with the PLC program.
Here is a screen shot of the display. Has anyone experienced a problem if the numerical display is grouped with other objects? I have done it many times without any problem. I don't know what else it might be though. The manipulation of F8:18 is done completely on rung #4 of ladder 2, there are no conditions on this rung nor any jumps above this rung. There are no macros or expressions that I can see.
One thing that may be a problem is the different versions of this file and the different versions of the panelview firmware. The panelview started it's life as a version 4 firmware. It got wet & stopped working so we replaced it with a new version 5 firmware panelview. I only had version 5 of the software so I just converted the old version 4 file to a version 5 file & downloaded it. This conversion happens automatically in the background whenever you open an older version file on the new software. Once it is opened you just have to create or compile the version necessary to match the hardware. I thought that would be better than attempting to lower the firmware of the new panelview. Maybe these grouped objects don't like being converted fron ver4 to ver5? I know grasping at straws now.
Old November 18th, 2009, 09:41 PM   #7
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
I have had issues with converting, but nothing like that. I once had different security codes applied to random screens after a conversion. That one took me a bit to find.
So this happened after the conversion? Maybe the update time for the display changed during the conversion?
You can right click on the display and select Display Properties to check the update time.
Just a WAG
Another thought that could blow my other theory out of the water: Do the other displays on that screen update slow?
Old November 18th, 2009, 09:46 PM   #8
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
This has my gears grinding...
I group things regularly and have never had any trouble.
I would try two things (one at a time of course). First, I would un-group them and see what happens. If you see no change, I would then delete the display and re-create it.
You can test it from your PC without downloading it if you have a local communications path set correctly.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
FTView 5.0, a Real Headache rleon LIVE PLC Questions And Answers 4 February 11th, 2009 11:40 AM
Inview Messaging Display sponge_bob LIVE PLC Questions And Answers 11 November 6th, 2008 11:10 AM
Controlling mesages on message display via SLC500 simpy LIVE PLC Questions And Answers 7 August 23rd, 2006 02:44 PM
Calling all Siemens S7-200 gurus mjamil LIVE PLC Questions And Answers 14 October 17th, 2004 07:22 PM
BCD to seven segment display Rich LIVE PLC Questions And Answers 8 January 28th, 2003 12:02 AM
