PanelBuilder32 and XP
JohnDruzianic
Mar 2007
Auckland
I have installed Rockwell PanelBuilder32 version 3.83 (newest) onto XP operating system (at the Service Pack 3 Level but without the option to step down to Service Pack 2 by removing SErvice Pack 3).
When I try open an existing Panelview app or create a new one, I get a message:
"Unable to locate dbtemplate.mdb in directory specified by registry or file may be write protected.
You may need to re-install PanelBuilder32".
Neither my application or dbtemplate.mdb are write protected.
I can not locate any reference to dbtemplate.mdb in the registry.
I have re-installed PB32 three times. All virus protection programs etc were off during the install.
Any ideas?
Can I raise this post from the dead and ask if anyone has found an "open to the public" fix? Thanks :D :D
63480 - PanelBuilder32 v3.83 DBTemplate error messages
Access Level: TechConnect (Rockwell really are a bunch of greedy a$%holes. This type of information is free if you use Siemens or Omron)
Date Created: 08/14/2009 05:05 PM
Last Updated: 11/26/2013 03:53 PM
Question:
Why do I get the following error messages when I open up PanelBuilder32?
"Unable to locate dbtemplate.mdb in directory specified by registry or file may be write-protected. You may need to reinstall PanelBuilder32"
"Unable to initialize the tag manager"
"Not enough resource memory to open dialog"
Answer:
This message can occur on Windows 7, Vista, or XP operating systems. It is more likely to occur on a newer operating systems that never had a previous release of PanelBuilder32 on it (or any other software that uses the offending DLL).
PanelBuilder32 v3.83 installs the latest MSJET40.DLL file, but uses API's for the MSJET35.DLL.
Solution:
The above issue has been corrected in PanelBuilder32 v3.83.01.
If for some reason this version does not fix the issue below is a workaround.
Workarounds:
Registering MSJET35.DLL if it is available on the PC.
  1. Go to Start -> Run
  2. Type 'regsvr32 c:\windows\system32\msjet35.dll' w/o quotes.
  3. Click OK.
Note*: If the file is not on your PC, then it can be acquired by an earlier release of PanelBuilder32. MSJET35.DLL is a Microsoft dll and is installed by other products, including Microsoft Office. It can also be downloaded from Microsoft.
You know this short of ***** really pi$$es me off. You own the software (legitimately I hope) and yet Rockwell requires you to pay a subscription just so you can have the pleasure of obtaining the information to repair their bugged software. Software for which you paid money for! And if you didn’t get the information here, if your distributor was unable to help, what could you do? The helpdesk won’t want to know you without a tech connect! They really can eat my...
By the way, happy to help!!!
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,425
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,082
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,625
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the...
1,255
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,596
