I want to read the real time clock from a s7-224 siemens plc. The problem is I can't find a description how to do it. I read it with the read-RTC instruction , setting the T-byte at vb100, but when I read the different bytes (hour , minute) with a move byte instruction it doesn't match the real value, for example the seconds run untill 70. Does anyone know how i can read them as 16# because when i read them in the staus chart and select hex it matches.
