Auto Dial-in to AB Remote Access Modem
rta53
Feb 2003
North Carolina
619
I have been asked by the powers that be at my company if there is any way to automatically dial-in to a SLC 500 that is connected to a Remote Access Modem. I created an Excel document with DDE link to Linx and I can manually dial-in and retrieve data. I do this twice a day to create a log sheet of about 48 analog inputs. This works fine if I am in my office but it doesn't get done if I am out. Someone suggested doing this with Visual Basic but I don't have any experience with it.
Read up on using Visual Basic for Applications (VBA) which is included with Excel. You simply write a script to automate the dialing and retrieving of data at certain times. It is really very easy to do, you just need to do some reading on VBA. Keep me informed.
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
74
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
161
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
347
I have 32 masters in a linear topology network chain. I would prefer to use AL1xxx series from IFM. They do support device level ring if that...
1,015
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
589
