Micrologix 1400 Communication with ADAM 4561 USB/RS232 converter
Tremaino
Sep 2013
London
Hi:confused::confused::confused: there,
I am trying to get an ADAM 4561 converter to talk via RS232 DF1 to a Micrologix 1400.
I know that some USB/RS232 converters simply won't support Autoconfigure on DF1, so Ive tried the default settings of ML1400 DF1 parameters; 19200 baud, 8 data bits, 1 stop bit, no parity, CRC error checking, but no luck.
Does anyone else use this device / know the configuration?
Regards,
I have that 4561 gizmo. Bought it about 4 years or so ago to configure some Adam Modbus modules, but that never happened.
Dug it out of a box last week because I now have a few modules for a project to set up.
Drivers ready to install, then plugged it in to a USB port per instructions, but it auto installed on an existing driver already present. Same USB to serial driver for the AB 9300-USBS.
Thought Cool, no issues, and it worked flawless for the Adam rigs.
Will it work with AB?, not sure and don't want to try because I have the AB rig in the same bag that uses the cables mentioned by TWS.
I don't like making cables, but in a pinch, I'll use breakout boards by ASI. Have a bunch around for those rare occasions, and they do come in handy.
Hello, I'm working on a project in which I need to communicate a Micrologix 1400 series C to a Zebra printer ZD230t through Ethernet/IP. Is there...
744
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,174
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,495
Hi, I am trying to communicate between a MicroLogix 1400 and a Click PLC. There is a great video from AD that shows the simplicity of...
1,759
Hi there, I am trying to communicate between Siemens 1214 that I have and a Micrologix 1400 on the other end through CIP protocol. I downloaded...
2,020
