RSLinx (Classic Lite) Ethernet/IP driver vs "Ethernet devices" driver
unsaint32
Oct 2012
minneapolis
365
Under the "Ethernet devices" driver from RSLinx, I see all my remote devices when my laptop's wifi is enabled.
Under the Ethernet/IP driver, I only see my local devices. Why is that?
Your Ethernet I/P driver is ether configured to query devices on "windows default" adapter or it specifically looking at your "LAN" ethernet adapter.
Right click on your Ethernet I/P driver and select Configure Driver. Here you will see which adapter it is using for the driver. Pointing it to the correct driver rather than "windows default" always works the best for me. I add 2 Ethernet I/P drivers and name them "Wired" and "Wireless". Then I point them to the correct adapter.
I see. Yes the IP driver had the Windows Default selected. Now, I want to try finding all devices connected through my laptop's wireless card. So, I am going to choose the wireless card in the Ethernet/IP settings, then select the Browse Remote Subnet. Then what address do I type in for the IP address of the router and subnet? You can see my IP addresses in the picture.
For the subnet I used 255.255.252.0. For the IP address I tried both 10.192.128.176 and 10.192.131.254. Neither is working. Could that be because I chose "Obtain IP address automatically" in the wireless card adaptor properties?
I've created a test program in Micro Starter Lite and attempting to set up communications with the emulator and run the program. In the...
1,577
Trying to communicate to a network using the two mentioned in title. Can't really find a good video on how to do it. If I choose AB_ETH-1 I have...
3,190
I am trying to Install RSLinx Classic Lite on a remote machine so I can use the Clock Sync Tool, But I keep getting this error. Error 1320.The...
8,130
I downloaded rslinx classic lite v4.0 today only to find its not compatable with my version of windows 7 ultimate, anyone know what the mjst...
1,594
Hi Guys, Can RSLinx Classic LITE communicate with a real PLC (SLC5/04) on program Downloading event?
2,738
