Greetings,
I need some help with the problem listed below. I'm running RSView32 ver.6.3.
Problem:
When RSView32 attempts to open a project, it stops at 50% and the Watcom SQL ODBC Login Screen appears with a username "tagdb" and a password "******". When pressing "OK" to login, the following error message is displayed and the project is not loaded: RSView - Database Conversion Failed Unable to connect to database server: Unable to start database engine.
Unsucessful Solutions I've tried:
1)
a) Click on the "User DSN" tab.
b) Click on the name of the RSView32 project listed under "User Data Sources".
c) Click the "Remove" button to remove the RSView32 project entry from the User Data Sources.
2) Unistall RSview32 --- Manually delete RTDSK40.exe --- Reinstall RSView32
I still get the same error message!!!
Anyhelp would be greatly appreciated!!!
Problem:
1)
