PLC data fIle backup
wa5yom
Sep 2003
Ardmore, Oklahoma
138
Here is what I want to do.
I have a machinie PLC that stores a lot of Recipe info locally.
I want to manually toggle an event to Write the data to backup PLC who's sole purpose is data backup/restore. In the event of a machine PLC failure I want to be able to download the backup PLC data to the machine PLC
After transmission to the back up PLC, I want to validate that the data is correct.
My initial thought is to validate with some sort of checksum.....or transmit the data twice. The first transmission would be to the real files that I would use to restore from...and the second location would be dummy files location that I could use to compare the data to validate the backup.
All of this would take place manually.
Any ideas?
Thanks,
Tim
There is really no need to do the error checking, it is already done for you.
Schedule a block transfer from one PLC to another. Transfer it back to the original if you want and use the FSC instruction to compare the data.
Hey guys, I have an unusual request from a customer of mine. They're asking to do a laser marking on some parts, ( no problem ) then read the...
4,443
Hi all, I am reading temperature from the analog modules, for the first stage of the experiment, I will keep my micrologix 1200 connected with the...
5,247
Hello Hello! Rusty here, looking for some advice from the experts! I have just started working on a project that will require an...
8,899
On page 12-5 of the Enhanced and Ethernet PLC-5 Programmable Controllers manual it says quote Important...
6,710
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
80
