AOI within an AOI
As cool as it is, recursion is caught by the compiler and not allowed in Studio/RSlogix 5K when it comes to AOIs or UDTs. A JSR call to "itself" is allowed but I haven't tried it without a way to "break" the call cycle. I would expect no less that a major fault.
I want to test it - but what if you JSR Routine_A, then have Routine_A JSR Routine_B, which in turn then has a JSR Routine_A. Similar for AOI_1 calling AOI_2, which calls AOI_1.
Would RSL/St5K catch that?
The compiler allows this; another form of recursion that could end disastrously.
The compiler caught this. I started with two aoi(s), aoi_A, aoi_B, with no local tags. I added a local tag in aoi_a of instance aoi_B. It was fine with that. I then tried to add an instance of aoi_B as a local tag in aoi_B. It caught it and indicated "recursion is not allowed".
I tried yet another level with aoi_c and it also caught that. aoi_A with an instance of aoi_B that had an instance of aoi_C. Attempting to add an instance of aoi_A to aoi_C tripper the same compiler fault.
Hi, all! I have a 1768-L45 CompactLogix PLC with a couple of 4-20 temperature transmitters connected to it. I have the temperature scaling...
473
Hi. Can anyone help me out with this one? This something that I am just having hard time figuring out. I understand and can also follow the run...
2,985
There was a bit of discussion on this in another thread (@Maintenance Man - Going from 500 to 5000). Instead of continuing to hijack the thread...
17
8,181
I am very new to Modbus and the industry, so forgive me if I am missing something obvious. I have known Modbus register addresses coming from a...
199
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
117
