KEPServerEX 6 on Factorytalk studio
keristos
Aug 2011
Malta
65
I am trying to communicated to a device through a KepserverEX 6 serve. I have FactoryTalk Studio running on the same computer.
I set up KepserverEx and I am seeing the data required on 'quick client' correctly.
I set up the OPC server on Factorytalk studio following the instructions here
I tried setting up a numeric tag in a display (again following the instructions on the pdf linked above) and when testing the display no data is being shown - just a blank numeric display box.
Troubleshooting:
1) I tried using FactoryTalk Live Data test client and I can see the data
2) When choosing the tag in Factorytalk if I right click on the tag -> Properties, it lists the value - which is correct. So I'm getting as far seeing the value inside Factorytalk but I cannot see the value in a numeric display.
Kepware Tag is set to 'Word' but I tried changing to a number of different types.
Any ideas?
Thank you
Hi everyone! I have a problem with FTVSE9.0 and Third Party OPC, i cannot read tags from opc server (KPEServerEX), and i do it without problems...
5,605
Does anyone know if it's possible, or the best way to go about adding a generic/ placeholder/ empty/ dummy tag to kepware? I used auto tag...
1,410
We are updating A few older Aveva Wonderware InTouch applications from a SLC PLC to a new ControlLogix PLC. What is the best way to deal with the...
1,082
I'm working on a system with around 12 Channels and different PLCs with different KEPServerEX drivers. We converted a PLC program to run on a...
17
2,940
I've setup another VM with KEPServerEX but it will not talk to the same PLC that the other is. It is seeing the PLC as it will show another error...
2,414
