Beijer Exter HMI No Protocol problem with Siemens PLC
BryanG
Feb 2005
Manchester
1,985
Spent the best part of the day trying to figure a problem with the Beijer Exter series no protocol mode. I got it sussed and so thought I would post it in case someone else hits the same problem. I realise that the Exter is an old HMI and I don't know if it applies to the Ix series.
I have the HMI connected to a Siemens S7-1200, but I think it would apply to all 300s and 400s as well. The standard format for a string is that the first byte holds the length of the string and from byte 2 onwards is the data. Siemens have their own system where the first byte is the string length and the second byte is the maximum length of string and so the data starts at byte 3. You might wonder what that has to do with the HMI 'no protocol' mode. Well it seems that if you set the string type to Siemens in the Exter driver that it also changes the format of the data sent and received in 'no protocol' mode. It doesn't mention that in the Beijer manual and a web search came up empty.
Hi Is there anybody on this forum who worked on Exter Touch Screens from Beijer Electronics. More precisely with the controller data exchange...
5,925
Hi, I'm currently having an issue with a Beijer T70 HMI. We have 2 HMIs talking to a Yaskawa motion controller via modbus over ethernet. The...
575
Does the Beijer Exter support PID blocks using the CLX (compactlogix)driver & using the L5K import . CLX Ver 4.15
1,829
Hi there, I have been working on a project using a small embedded controller called a SPLat (www.splatco.com) with a Beijer Exter t70 HMI. I have...
18
6,911
Is it possible to exchange data between compact logix and Moore(Siemens) DCS through Exter HMI Screen? I am using Compact Logix L35E processor and...
6,032
