"RS logix 5000 Question" Having trouble Creating produced or Consumed tags online
randy741985
Oct 2006
US
154
Having trouble Creating produced or Consumed tags online...Can anyone tell me. Is it possible to create a produced or consumed tags online?
dmroeder said:
That's because you can't. You have to create them offline and download.
OK Thanks
Quick question If you change the proceesor to program mode then would it be possible to do this and not have to do a download?
OZEE said:
No, you have to create them offline and download.
One other question ozee
I am trying to add a producer for a consumed tag in a CLX program but im having trouble configuring the producer in that program. It is going to be on eithernet network not the backplane.Can you Give me some direction?
Attached images are for CompactLogix, but theory is same for Clgx
In the consumer, you must create a link to the producer:
Then create a consumed tag, and in the connections properties, provide the name of the plc to link to and the name of the produced tag
Then in the producer PLC create the Produced tag and how many connections are required
How to find consumed tags in a program
I am doing an upgrade for a customer and I am having trouble finding all the consumed tags. Is there any way to find all the consumed tags?
You should probably start a new topic, rather then add a post to one that is 7 years old, but....
Open your program, go to the controller tags, click on the 'Configure' filter, Select "Consumed" from the drop down, and select all tag types.
hi , I need to sorry for my bad English first. I'm newbie at plc programming ,I had been asked about E/IP protocol information for some system...
377
So I have a PID loop on an 1756-L61 running V17 software just for background. Also the PID PV is a pressure transmitter and the CV is speed sent...
893
Good morning guys, I have a machine that fills bags of prepared food at a variable speed, and a machine that checks the weight of the bag. What...
23
6,821
Hello Please Help, I want to use a FSC instruction that will scan 20 DINT arrays. If the arrays are greater than 1000 display the value. How do I...
1,761
Hey all, I just joined today. Not sure if this question is in the right place or if anyone has asked it before. I am monitoring a machine from...
1,443
