Panelview tags for a PLC5 Conversion to Controllogix using 1771 IO
kswanger
Jul 2015
Missouri
Hi all,
I have used your forum a lot in the past for helpful hints, but I could not find anything on this question.
I have a project where I am converting a PLC5 to a Controllogix PLC and then using a 1756 RIO to communicate with the existing 1771-IO. I know there are multiple topics on this, but my question is what is the best method for this so that I do not have to rename all of the HMI tags (over 1000)
Once I map my tags through RIO in Controllogix I have tag names such as PLC5_I001.0 instead of I:1/0. The only method I can think of for changing these names would be to export them into a spreadsheet from the HMI and change them that way. And then re-alias them to their correct tags in the PLC program as well. So that whatever was mapped to I[1].0 becomes an alias for PLC5_I001.0 instead. Is there a better method that I am not thinking of?
Any ideas that you may have are much appreciated.
Export the tags to CSV and change them in Excel; you have the right idea.
I'm pretty sure that any PLC to ControlLogix conversion = new tag names
If the changes are all the same, you should be able to do that very quickly (<10 minutes).
Ex. search & replace all
"/" with "."
"I:" with "PLC5_I00"
I am working with a Micrologix 1400 and a PanelView plus Compact HMI. There are some HMI tags that are present in the HMI that is actively using...
2,714
i have created a panelview app that has two pages. each page has an overview of a canning line. page one: all the objects are using HMI tags...
1,316
Currently I have a panelview talking to a SLC processor but I am upgrading it to a compactlogix. Unfortunately there was never a tag database...
5,025
Good afternoon, I am new to programming the PanelView series from AB and need some help with getting my tags to work on the HMI created by OEM. I...
2,032
I'm looking to create my own 'screen saver' screen on a PV800 and I cannot find a tag thats suitable to read back in the PLC that i can then write...
2,925
