Toshiba T3 PLC Computer Link <-> RS-485 (real time data extraction)
vincentc
Feb 2017
Bangkok
Hi everyone,
I need to interface an external PC with a Toshiba T3 CPU (model PU326H) in order to read data from several 'F' registers.
The external PC sends data via RS-232 to a RS-232 <-> RS-485 converter, then that converter sends data via RS-485 to the Toshiba T3 PLC "Computer Link" port, located on the bottom of the Toshiba T3 PLC.
The setup I have enabled so far is as follows:
Select System Parameters
Inside Computer Link Setup, choose the station (=1)
Inside Computer Link Setup / Communication Parameter choose Baud rate = 19200, Parity=None, 8 data bits, 1 stop bit
See full setup visible from here:
https://www.dropbox.com/s/uoqfj3v08c3dp6u/PM3%20overview%20for%20Toshiba%20PLC%20experts.pdf?dl=0
The problem I am having is that while I can send data via the RS-232 converter, no data is sent back from the Toshiba PLC.
Has anyone ever setup the Computer Link port on a Toshiba T3 PLC? Any clues as to what is causing the issue I am observing?
Any help is appreciated, thank you.
Regards to all members.
Has anyone had any luck getting a Rockwell PLC (Compactlogix with Ethernet/IP) to communicate to a Toshiba TS3000 with Ethernet/IP. I imported...
1,690
Can anyone help. I have an old toshiba ex M40 which needs to be updated to a Rockwell PLC (probably micrologix). I have (what i believe is) an old...
1,937
Hi, I am looking for manual book plc toshiba ex 40 plus, these part have prob led error lit Please help me to solve this problem, thank you in...
1,831
I've got a Red Lion G304K200 HMI connected to a Toshiba T2N PLC, and I am attempting to display a pressure value, which has the address of XW000...
33
11,191
We have a few machines here that have Toshiba EX100 PLCs in them. I found a programming cable with hardware dongle on Ebay. I am getting a no...
5,253
