connect a PWM output to a differential or photocoupler input of a PLC
eponge
Apr 2010
Princeton
Hello all,
I have a PWM output 100mA, 50 Ohm from a CMOS driver. I want to connect it to a pulse input of a input/output card of a PLC. The pulse inputs are differential input (5V) and photocoupler input (5V). Any suggestion on how I should connect them? The pulse inputs to the PLC require 3 wires: pulse -, pule + and pulse input ground. The PWM output is a BNC female connector.
Thank you for your help.
86
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
91
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
332
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
284
Hello, friends, I am trying to upgrade a system that uses an Onrom incremental encoder (E6B2-CWZ6C) connected to a Danfoss VFD (FC360), but now...
271
