Wonderware and ArchestrA
Nov 2011
Ireland
182
Hello,
I have installed Wonderware Intouch and Archestra on my PC. the window maker and Archestra IDE open by themselves individual fine.
I want to use archestra graphics in windowmaker. I believe that there is suppose to be a symbol called "archestra graphic library" on the windowmaker tool bar
I cannot find this symbol to open the Archestra graphics. can anyone tell me where to find this symbol or how to open the graphics library within window maker
regards
hi Benny,
Depending on your version you can go to the menu " View" in the toolbar and check that your "wizards/active x controls" are selected. Then a icon will appear which looks like a wizards hat. click on that then a menu window will open " Wizard selection" . There you will find a variety of wizards including " Symbol factory". The newer versions have embedded archestra graphics when you select the Wizard hat in the toolbar.
Hi All I'm a novice starting to work on WW and Archestra, I've been adding repetitive attributes on the front end which has been tedious and was...
2,079
Hey I was needing help with some alarm scripting in Woderware System Platform. What would be the best way to write a script to auto acknowledge...
2,544
I am trying to create a script in an Archestra graphic that will eventually talk to an Omron PLC. I need to access the elements that I create for...
1,614
The application is not getting deployed after a power failure. After the power got restored, I tried to deploy an updated instance but the...
4,032
I have to work on a Wonderware HMI and have very little experience with it. The basic idea is to copy an old project, make a few edits, and load...
4,911
