Fanuc Robot Heads - Have any of you tried Wireless I/O ?
Cydog
Feb 2018
Maryland
313
Good Evening ,
We have had a problem with some broken I/O wires on a Fanuc Robot. I'm sure we just need to rerun some cables , but I was wondering ..... Have any of you tried to use Wireless I/O from the robot base to the head , and eliminate most of the wiring ?
Yes I have done this. You won't eliminate everything, you will still need to bring 24V+ and 0V to power up stuff and and of course compressed air.
It is an expensive option, so recent times I keep all the electrics and valves grouped together on the arm and just bring a loom of polyeurethane pipes down onto the gripper. It is easy enough to do this and if a pipe is damaged it is not a hi tech job to fix it.
Has anyone ever tried to integrate a Raspberry Pi to a Fanuc robot? I have this idea that I want to try out but I need to write integers from a...
1,543
Just wondering if anyone has had any experience with using a Fanuc Robot (R30iB) to a Logix 5000 over Ethernet/IP using Safety. I have some...
1,574
I have read every post I can find on how to interface an Automation Direct C-More EA9 series HMI to a FANUC robot with no luck. Some say it is...
3,077
Good morning, I am currently in Nigeria and I came across a problem with a Robot fanuc that is installed in a Huky injection machine. The teach...
1,901
I have a Fanuc Robot F-200iB Series 9, 6 Axis and it is running on R-J3iB controller and the controller is configured to Mitsubishi PLC Q06HCPU...
1,893
