plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 25th, 2020, 11:59 AM   #1
abderrezak
Algeria
abderrezak is offline
Book Omron CP1H Write protect
I recently had to buy a batch of new electrical components containing
10 PLC Omron Type (CP1H-X40DRA) Apparently stored in store (to be used as spare parts).
And when we check them, I see that they are in perfect condition and that they are already programmed for the applications for which they are intended, which did not interest me since I intended to use them for my own applications.
To my surprise, I see that I cannot download my program because of the write protection (by checking of course that the DIP SWITCH n˚1 is OFF)
The following message appears on CX Programmer on each attempt:
Erasing program memory failed.
The program memory may be protected in read mode with prohibition of erasure.
I understand of course that we have the right to protect a program against reading or modification, but here to condemn the PLC that we bought and to prohibit the reuse of hardware is something that seems unfair to me!
I also doubt that maybe it was I who did not know how to reset the PLC for my own use (Despite my research on the specialized Forums).
Please enlighten me on the matter or guide me how to remedy this problem.
online status of AR99 (Relative to read / write protection)
AR99.00=1: UM read protection is set
AR99.01=1: Task read protection is set.
AR99.02=1: Overwriting prohibited (write-protected)
AR99.03=0: Creation of backup program file allowed
Thank you for help
Thanks for help
Old March 25th, 2020, 01:39 PM   #2
BITS N BYTES
United States
BITS N BYTES is offline
Put PLC in PROGRAM mode. From PLC pulldown menu Select "Clear All Memory Areas". Select "Initialize" then "OK"
Old March 26th, 2020, 06:17 AM   #3
abderrezak
Algeria
I've already done it
The response is :
failure to erase the entire memory area
Thank you
Old March 26th, 2020, 08:47 AM   #4
sbaum
Canada
sbaum is offline
I haven't researched this, but does it work to pull the battery for a while?
Old March 26th, 2020, 11:28 AM   #5
abderrezak
Algeria
I removed the battery for 1 month and nothing changed
Old March 26th, 2020, 01:50 PM   #6
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
On the front of the CPU, you will see dip switches. I believe that the first switch is UM protection. Make sure that it is off and try to erase the program.
I hope this helps you out.
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old March 26th, 2020, 02:25 PM   #7
gclshortt
Canada
gclshortt's Avatar
Oh, I see that you have tried the switch setting.
http://www.plctalk.net/qanda/showthread.php?t=81125
This was a similar thread but they knew the password.
Can you turn off AR99.02?
If so then try to then erase the program.
Just a thought,
Regards,
__________________
Garry
Old March 26th, 2020, 02:38 PM   #8
AustralIan
Germany
AustralIan is offline
Hmmm, I guess it prevents someone from hacking the machine. "just flick this switch and put whatever you want in place."
It might be you have to call your omron dealer and ask them how much to "repair" the PLC so you can program it anew.
Old March 27th, 2020, 04:59 AM   #9
abderrezak
Algeria
A99.02 is read only, I even tried without success
Thank you
Old March 27th, 2020, 05:00 AM   #10
abderrezak
Algeria
Thank you
Old March 27th, 2020, 05:08 AM   #11
abderrezak
Algeria
An idea came to me, but to try it I need the help of someone with the same type of PLC (CP1H-X40DRA)
It is a question of making a backup of its empty plc or whatever with the PLC BACKUP TOOL in cx-programmer and sending it to me to do the reverse operation by overwriting the program in the UM of my PLC
I think itís possible especially seeing the online status of AR99 (Relative to read / write protection)
*****AR99.03=0: Creation of backup program file allowed ********
Thanks for help
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RSLogix CIP Datatable Write allenz2123 LIVE PLC Questions And Answers 3 December 14th, 2014 04:23 PM
Beginning Omron CP1H CP1W bernie_carlton LIVE PLC Questions And Answers 9 May 8th, 2014 06:38 PM
problem with write protect for plc s7 program mohamed atta LIVE PLC Questions And Answers 0 October 16th, 2011 02:14 AM
omron again??? fuzzywuzzy LIVE PLC Questions And Answers 1 February 10th, 2007 11:21 AM
