Control Logix Redundancy
salman111a
May 2007
KARACHI
20
I am having problem in synchronization of redundant chassis. As per redundancy bundle V15.57 package i have update firmware as below
Slot 0 Ethernet module 4.3.2
Slot 1 1756-L61 15.57
Slot 2 1756-CNB/E 11.02
Slot 3/4 empty
Slot 5, 6 1757-SRM 4.4
Well i have done the scheduling of control net..its working fine.. when i eject both ENBT card from both redundant chassis ...then both SRM module get synchronized ..as soon as i inject these ENBT modules then SYNCHRONIZATION gets terminated...
When i start synchronization from Rslinx then i get message......module configuration error......ENBT module has disqualified request for synchronization
I have upadate firmware of ethernet module many times...........Also i have changed the firmwares of all modules as per redundancy bundle of V15.60 but m getting same message
Do you have the 1756-ENBT modules set for the same IP address ? The -SRMs are supposed to manage them (primary=IP, secondary= IP+1) and you're supposed to set them up the same.
That's all I can think of offhand. Redundancy systems are complex enough that you ought to call RA Tech Support and have them help you through the codes reported by the Redundancy Module tool.
hi, this is my first post in this forum, i have two allen bradley 1769-L30ER and unfortunately I want to make it redundancy. but I heard that...
3,027
Hi! I am working with control logix 5570.I am facing network glitch in FT SE when controller switch from primary to sync. Chassis - I SLOT...
2,377
Hello and thank you for taking the time to view my post! First of all, I've attached an image as reference. What I am trying to accomplish is...
4,318
Is is possible to give some command and swap the control of primary and secondary irrespective of any fault. like using a digital input command.
1,640
We have L61 redundant existing plc. when we add new en2t module after configuring it inside the logic, the secondary going DISQ. Please advise...
3,801
