Micro 820
JohnnyQuanex
Nov 2015
Cambridge, Ohio
120
Hello Board,
I just got a control installed over the past weekend for one of our applications... I have never used any Micrologix stuff... The programming and commissioning was done my the machine builder... I got Connected Component Workbench installed on one of our programming terminals and am trying to connect and I can't get RS Linx to show it in the network trees...
I setup the IP address protocol on the terminal and I configured the Ethernet IP driver in RS Linx...
The Micro 820 processor is faulted (happened last night sometime and nobody knows when or what happened) so the line is down and I'm trying to get connected so I can investigate (and hopefully clear the fault...)
Any advice would be appreciated...
I called the machine builder, but they won't be available to help right away...
Thanks,
John Whited
I just didn't have my IP address setup right on my programming terminal... I thought I did, but must not have... I went through and checked all the simple things again and then it showed up on the network tree...
Just need the IP address to be right and the Ethernet IP driver running on RS Linx...
Thanks,
John Whited
Thank you, It is always good to know the outcome.
It will help someone somewhere sometime.
OH, by the way, been there done that. Not the first person to have done that and definitely not going to be the last. 🍻
Brian
One thing I have noticed is that when I change my IP configuration and hit "OK" on the IPV4 Properties Dialog box, is that the changes don't seem to take effect until I also click "OK" on the Local Area Connection Properties dialog box...
This might be simply because I didn't wait long enough... I have been known to be a little impatient... but I developed a habit of making sure to hit OK on both windows before I expect the new settings to begin to work.
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
274
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
343
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
939
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
467
