Connect a Micrologix 1100 to a Powerflex 40P
Arnildo,
I am new to the Micrologix 1100 myself, so I am not of much help (yet), but I did read this thread earlier tonight when researching the Micrologix 1100 and ethernet...
http://forums.mrplc.com/index.php?showtopic=14133&mode=linearplus
It is a long thread, but has interesting info regarding things to watch out for when using ethernet for controlling drives. What is your application? What are you trying to position? What tolerance? What type of position feedback is in your system?
I just landed a job designing an automated Dynomometer tester where I am planning to use a ML1100 to control a General Electric AC drive for speed, but I was planning to use 0-10v control signal for the speed. As I learn more, I will try to help you if I can. I will be learning very quickly because I only have a month or so to design and install my whole system!!
respect,
frenchy
Hi Frenchy,
Thanks for your help. I'm right now declyning on ethernet comunication in this application... I will probly use PTO to control the number of pulses I will need to acchieve my position. I have two weeks to figger it out how to do this...About your questions, to receive a feedback I will use an encoder, my tolerance it's quite big, 1mm or so. My applictaion is a press, I don't really know how to explain it in english, but feeding is the secret in the system, a have to tell the drive to turn on the motor to spin until my desire lenght of material and then stop, with out a help of a stop device, like a sensor. It's basicaly this, see you.
Arnildo
I have a broken Micrologix 1100 here - the serial port is damaged. My only way to communicate is through the ethernet port - but I don't have...
2,870
Hi all; I know I have to be missing something relatively simple, but for the life of me I cannot find it: I'm setting up a ML 1100 for a small...
4,465
I was doing some testing on a Micrologix 1100, and during the test the PLC faulted. Fault light is blinking red. On the LCD, it shows Major...
2,665
Hi, Everyone I am a beginner to PLC. I am currently working on a project to build a door cycle tester. Allen Bradley Micrologix 1100 is used to...
4,266
87
