FT View - Search and Replace window
MHammer
Sep 2017
Midjutland, Denmark
20
I have this problem with the Find & Replace function i FT View. I am not able to see the whole window. I do not know what to do, but if someone could attach a screenshot of the correct window in this thread I would be glad.
Then I'll be able to see the things I'm missing out.
Thank you
Are you running this in a VM? I've attached an image of what mine looks like.
Try setting your display scaling in windows to 100% and see what happens.
Also choose one of the default desktop themes.
Thanks to both of you.
Jeev, it's running normal on a Win8Pro and no VM. Thanks for the screenshot.
Geoff, it was on 100% and that's why it looks like that, so I put switched it to 125% (Windows standard) and it looks normal like the one Jeev attached. But I do not want windows to be scaled up, so I figure I'll have to make do with the small version at 100%.
Thx
//Hammer
Good morning folks, I'm on a quest to find all of the references to the CurrentUserHasCode function in our project. I have the project...
430
I know in Siemens WinCC you can search where tags are being used (display -> object). Is there a way to do this in FT View Studio?
2,603
Hello Everyone, I am searching doing a search using my compact logix L33 and I want to show all the data found ( it can be as high as 60, 70...
3,020
Hi Guys, Is there a tag search function in RSView Studio similar to the old function that was available in Panelbuilder 32 where you could...
3,040
Hello to everyone, I have a question about how to find a tag where it is used in the Factorytalk View ME? Something like cross reference in the...
13,333
