Modicon 984 serial to ethernet
vtfan
Nov 2003
31
Hello all.
I have a customer who has a Modicon 984 PLC system in place. Currently, this PLC is talking to an Intellution station via RS-232 connection.
This facility is going through a large scale upgrade of their other PLC's in house, mostly AB 5/04 to 5/05 for Ethernet comm's.
This 984 PLC needs to do the same. I'm looking for some input on a serial to Ethernet converter, Ethernet card to put in the existing rack, or an upgrade of the processor (and only the processor) for the existing 984 I/O rack.
Any help would be greatly appreciated. We can get the proper Intellution drivers for Ethernet comm's once we settle on a hardware upgrade / conversion.
Thanks,
Pat
You don't say what model processor you have. There are rack mounted convertors for the Quantum family and the new generation of Compact controllers.
Your best choice is probably a stand alone device like the Modicon 174CEV30011 Modbus serial to Modbus TCP convertor or a similar product from Lantronics or B&B Electronics.
As mentioned, Modicon makes the Modbus to Ethernet bridge. The part number is 174 CEV 300 20. The part number has been recently changed to the 20. I have been using this setup for a couple of years now with good results. Another way to do it is: put in a Quantum rack and processor with a remote I/O head (CRP module) and convert the program to Concept then run the 800 series as a remote I/O drop. This works well also. I have heard that Modicon might be developing a terminal board adapter that will allow plugging the existing 800 series terminals directly to Quantum I/O modules which will greatly simplify upgrading to Quantum but have not actually seen one yet.
Steve
PLC Serial Connectivity Issue with a Modicon 984 and Modsoft 2.21 Hello all from PLCtalk.net, wondering if someone has any words of wisdom to...
5,661
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
200
Hi I have a modicon 984 with proworx 32 that is scaling an analog input, and I need to adjust the scaling. I have new analog input values and %...
1,721
Hi, I am trying to get a machine started that was moved from one location to another. It has a Modicon 984-A131 PLC. I have Schneider Electric...
1,010
Dear Friends, I have Schneider PLC which is the world's first one Modicon i need software of Modicon PLC 984,it is known as...
962
