Updated FactoryTalk View to 10.00. Now having issues with RS Linx Enterprise.
Rob S.
Sep 2008
Maryland
739
Happy Thanksgiving ,
I just recently updated my FactoryTalk View to version 10.00. Now I'm having issues with RS Linx Enterprise. Cannot drill down to my processor to PLC , Cannot see my Panelviews when downloading using Transfer Utility, and a few other strange things. Have any of you had this problem , and if so, what did you guys do to fix it ?
Thanks so much and have a great day ,
Hello, I have seen FTView 10 only once but I thing it has changed in therms of RSLinx Enterprise and how you configure your connections.
What you experience might be normal and you set up/browse your devices different way.
Correct me if I am wrong guys.
Thanks ,
I would think that the correct FactoryTalk Service Platform would install with FactoryTalk View 10.00, unless the same is used for RS Logix 5000 .
Where do you see what version of FactoryTalk Service Platform you are using ?
Chopin , yesterday is when I first noticed that I no longer could drill down to my processor in my Shortcut in FactoryTalk View Studio ME. I had to had a device . In Transfer Utility I don't have that option . It is so discouraging because I'm behind in this project , but now I'm dealing with Rockwell issues .
I probrobly have enough of my own program errors to deal with , and not enough time to deal with Rockwell issues.
Thanks again,
Right I dig out the right VM with FTView 10
First thing is to add a comms server. Right click and add it.
It should now appear in the project tree. Double clisk on it to open a comms setup.
Then in the new window right click and add a driver you need. Once this is done you should be able to add the correct device.
Hope it make sense and helps a bit
Thanks for the time your investing in this.
I looked in installed programs and I have ....
FactoryTalk Service Platform 3.00.00 and FactoryTalk Linx 6.00.00.
You can't open FactoryTalk Linx separate , correct ? It is embedded in FactoryTalk View , correct ? When I do what you said , will it correct my issue in Transfer Utility , you think ?
FT Linx is a Rockwell product data server. I do not think you can open it directly. It is embedded in all Factory Talk products - Historian, Vantage Point ect.
You have to try it, I was able to setup a communication and seems to be working but i do not have hardware only using emulator.
Once you follow the steps I have suggested. There is one more thing I have not mentioned. You need to copy your design settings to your runtime by pressing a button (see image)
Yes Sir , that is what I had to do yesterday. What I am trying to do now is download my runtime application to a Panelview Plus 700. So you think if I setup my FactoryTalk Linx in Explorer , that the link I connect in Transfer Utility ?
hey guys i've been trying to find an updated SW files of my danfoss fc360 for MCT 10 software but i couldnt be able to find it anywhere on...
249
I have this program: ZIP (.rss inside no documentation). PDF (Italian documentation). Allen Bradley SLC5/03 PLC. I want to know how is the...
2,041
Hello everyone, I have a SIMATIC s7-300 CPU 313-2 DP[ORDER NO:6ES7 313-6CF03-0AB0] with firmware version 2.012. I want to update the firmware with...
2,051
Good Day All, I currently have a request to update an AOI and a shutdown of the place it's to be updated has to be shutdown which is not...
1,824
I recently installed a new centrifuge in a production facility. They were already using AB PLCs/Panelviews and had RSLogix/Linx etc installed on...
3,286
