Connected Components Workbench and Micro 810 questions
We have quite a few Click PLCs in service in various applications and have not had any trouble out of them. Most are the Ethernet capable models that do support online editing. The software is free and simple to download and install. It is not quite as good as RSLogix, but a far cry better than Directsoft.
Thanks for the info on the Ethernet capable Click. I sent several emails to them here in Oz and they have not even responded. Not impressed with the service at all!
I have found their phone tech support to be good. But they don't work Oz hours :-(
Click PLC is very basic and no online programming? Never! Will not use anything that does not have online programming these days - too hard to shut down plants to do a small change.....
It depends on the application. As already noted, the Ethernet versions do permit online editing. Making changes to the program for the basic version doesn't take long. But, if the particular application is connected such that you would need to shut the plant down, I would definitely go with an ethernet click, or more likely, upgrade to one of the Productivity series. More expensive than a click, but still a bargain for the capability.
In the applications I am using Clicks, you'd never know it on other ends of the facility if I shut down the machine for the 30 seconds or so to upload the program...
was trying to use Connected Components to connect to a 525 drive via usb with the face off but can't seem to connect to it. the screen lights up...
788
So I'm using CCW to program a panel view and this is not my first I have done many. My Problem is I get an error message that I have never seen...
494
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,280
I’m working on a conveyor project for work. We’re trying to install a few diverts to carry product directly to one of two trailer doors. I have...
1,050
I cannot get CCW to add a controller, i keep getting a error message saying that the device is not authorized. This happens with any model and...
1,364
