Windows Update and RSLogix500 V16
curlyandshemp
Jul 2005
Toronto
1,903
I just had a Windows 7 auto update applied, and now my V16 or RSlogix5000 no longer will launch which worked before the auto update. All other versions of Rslogix 5000 are ok.
Reinstalled V16.4 , but still will not launch.
Anyone else?
What were the updates that were installed? I'd remove them one at a time. I wonder if one of the updates was with .NET 1.1 (as Contr_Conn is suggesting).
I'm going have to try launching it tomorrow.
If Fatal Error file listed as "Unknown" line -1, then this will be DotNet most likely
V16 uses ver 1.1
Windows 7 must have DotNet 1.1 SP1
This will be my guess
Blame Microsoft :)
There are plenty products that revert .net 1.1 to original state( pre sp1) but windows 7 depends on it
Blame Microsoft :)
This is one of those frustating situations that those suit and ties in Seattle and those suit and ties in where ever Rockwell's suit and ties reside don't realize what we guys in the field have to put up with.
Thank god for this forum, because I would have been pooched waiting to call Rockwell on Monday morning as the $7K in Tech Connect support fees our company pays only allows us the privilege to talk to Rockwell Monday to Friday 8-5.
And most of our Tech Connect calls are regarding activation issues.
Just think it this way:
If you would not pay for your toolkit, some of us in this forum would not have a job Mon-Fri finding these answers to help you on weekends.
Clear enough?
It is very likely the .net framework problem.
I have problem installing the V16 on Windows 7. I read all the post here. I checked that I already have a .NET framewrok 1.1 installed a few month ago. So I decided to uninstalled the .Net Framwork 1.1 that I had. Then reinstalled the RSlogix5000 V16. It turns out that V16 pumpt and ask me to install the .Net framwork 1.1 during the installation. After I proceed, works.
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/1133982 What kind of hiccups could be expected before Rockwell puts out...
4,439
Hi All, I'm sure I'm not alone with this issue. A recent Windows 10 update for the Meltdown-Spectre issue has caused RSLinx to start failing, I...
2,745
So I just had a update on Windows 10 on two separate PC's and both are failing on RSWho anyone else having the issue? Both are the same issue...
3,040
A few days ago, I was fixing some settings but accidentally set the windows 10 update, and so it did. Yesterday, when I opened my rslinx, i got...
4,096
The last I saw for FTVS-ME 8.2 it was going to be some time in June. I hope that it is going to be this year and not 2017 as there is only 1 day...
2,032
