Looking For Input On How To Change Over A Process
esp400
May 2015
Milwaukee
69
I'm working on an automated robot cell. The robots function is to take parts off of an assembly line and store them until the cell which produces the parts stops running for whatever reason. When the cell stops running, the robot starts putting parts on. It essentially acts as a buffer to keep the line full and people who work on the line busy performing secondary assembly procedures. I currently have a BSL instruction set up which tracks the status of 40 bits which represent the 40 physical spots between the offload of the cell and the pick point of the robot. When one integer file fills up, the decimal value is -1. This is the value right after 32767. What I need is a way to tell the robot to change from picking off parts to putting on parts. At minimum, I think I need to monitor around 32 bits. It takes about 10 seconds for the changeover so that the storage automation acts in a FIFO manner and the line moves at about 100mm/s. Does anyone know a good way to monitor these two words and evaluate them?
Thank you!!
How it is done depends on your software, but in general you need to use bitmasks to perform this task. This allows you to evaluate each bit of the words and determine a task based on the value. See this general article on bitwise operators if you aren't familiar with them:
https://en.wikipedia.org/wiki/Bitwise_operation
Hi everybody, I have a situation where we have a Cartesian robot sitting on top of an injection molding machine. There are 3 cranes in the bay...
2,122
Who here owns or works for a small system integration/automation engineering and contracting company that is willing to share some information to...
2,718
Following on to my previous post regarding an HMI recommendation---Could those of you that are familiar with Ignition provide your thoughts and/or...
2,509
If anyone has one they'd like to sell, please PM me. Alternatively, if anyone has two temperature transmitters (4-20mA), please do the same. The...
1,288
I am looking for a small block PLC (properly 6 DI and 6 DO) with 2 channels analog inputs (at least 10 bits resolution). I will use it for a...
22
8,440
