MicroLogix 1400 Modbus
Sapper307
Nov 2017
Maryland
107
I'm setting up a 1400 to be a modbus TCP slave. under the channel configuration dialog box i've enable modbus on channel 1 (it already had an IP and subnet for a pre-existing TCP/IP connected HMI), which gives me a new tab. i've configured the modbus tab to define my contact and holding registers and said ok. it created my new data files (B20 Contact and N21 Holding).
what am i missing? I can't find anywhere to define the slave address in the settings. All the online help references to modbus slave address are how to configure the 1400 as a master, not a slave.
Thanks in advance.
Modbus TCP does not use a slave address. You have a UnitID which is normally 1. The master identifies slaves based on IP address and UnitID.
Can't remember off the top of my head whether the ML1400 has a configurable UnitID. Just try 1 or 254 if your master requires one to be entered.
right. i guess i was interchanging "slave" and "unit id". I can't find any settable "unit id" field in the config. I was going to try 1 by default, cross my fingers and hope it talks. I'll find out soon enough... commissioning tomorrow.
thanks for replying
I want to learn about modbus communication and I saw on another thread about inexpensive modbus relay units so I found it on Amazon along with a...
46
7,227
I have a spare Micrologix 1400 Series B I bought used on Ebay awhile back. I had thought of it as a spare PLC for my train project but I screwed...
1,254
Good Day! Would anyone be able to explain what is happening with the COP's and MOV's in this Modbus poll routine? If anything I am confused by...
1,731
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,509
Hi, I am trying to communicate between a MicroLogix 1400 and a Click PLC. There is a great video from AD that shows the simplicity of...
1,770
