Would someone want to l00k over this weintek hmi program please
TK6070? Are you running MT6070 or TK6070? The TK is Chinese only. Must be run under Chinese Windows, and EB8000 set to Chinese.
I've tried the suggested workaround without success.
Yup I am using MT6070iH VW5 these came from china with the cables with the guys who installed the lines. Hmm I guess ill look for another cable to try.
I've used the MT8070iH before on Micrologix and made my own cable using this the cable connection guide. I do have 2 different copies of the connection guide, here is a copy of the FX2N Connections from an older Connections Guide, It does show the PLC side as RS422 but has the same pin out on the cables as the first one I sent, Again I am not familiar with Mitsubishi PLC's
I think that its reversed and you should be looking at it as if it was from the back
I buy the 8 pin Mini Din cables on ebay and cut them and solder to 9p D sub
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
370
Long story short lost our parameter setup for an indradrive m. I have these files saved as backups but dont know how to open them. Can someone...
896
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,079
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,620
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,594
