"unsupported feature in configuration" versamax GEIP
sultanahmed
Jul 2013
home
63
Hi Experts,
I havebeen working on Versamax GE PLC CPU IC200CPU001 Power supply IC200PWR001
with I/O modules IC200MDL244(Input Module), IC200MDL940(Output module) and Carrier number IC200CHS022.
PLC is on Fault when i check diagnostic it shows Error "unsupported feature in configuration" Picture is attached.
I replace each module and each carrier problem is same.i checked configuration also which is also match on Proficy machine edition(version 8.5).
I checked CPU individually with out any module it is working fine.
Please help what exactly problem is???:confused:
Hi Experts, I havebeen working on Versamax GE PLC CPU IC200CPU001 Power supply IC200PWR001 with I/O modules IC200MDL244(Input Module)...
3,329
Hey all, Made myself a decent application in FactoryTalk, when testing the screens with the "test display" btn everything works fine. Then I...
4,156
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
476
Someone has Unsupported Utilities from TwinCAT 2 CD, I need TcAmsAdsDebug, MS Network Monitor dll, TwinCat Monitor (TcAmsLog + TcAmsAdsViewer)...
1,669
First time I've encountered this; a fellow controls guy here compiled the project into a .mer and downloaded the project. The panelview plus 7...
6,829
