codesys "object reference not set to an instance of an object"
lesmar96
May 2017
PA
520
SoMachine v.4.3 which is Schneider's version of Codesys.
I am writing a small program. One POU is in SFC But this message box pops up and says "object reference not set to an instance of an object" I get this message any time I try to build the program or log into the controller.
Everything works fine in all the POUs and it builds just fine until I add the program call for the SFC POU. Then I start getting this message. The SFC POU builds just fine without any errors, and it is only after I add the program call under task configuration that I start getting this message.
Any help on what is wrong?
I haven't used SoMachine but I do use TwinCAT (Beckhoff) which is also based on Codesys. I believe the "object reference not set to an instance of an object" error may have to do with instantiation of function blocks. You can't use a function block without creating a variable instance of it... in other words you can't just put a TON in your program, you have to create a variable myTON of type TON and call that. You likely know that already but it's something to double check.
I've found with TwinCAT that a program or FB isn't fully checked/verified during a build unless it's included in a call from the main POU. That may explain why the error doesn't show up until you add it to your task.
Not versed in TwinCAT but do you have a target specified. Going from memory but I have seen this message before and I seem to remember it coming up when there was no target hardware specified.
I talked to Schneider tech support and they told me basically the same thing as this.
I was trying to find the issue and made some changes and the error has gone away, but I wasn't 100% sure which change I made caused the difference.
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
286
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
139
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
499
I am trying to get Codesys to work with a couple of Moxa ioLogik E1200 series DIO devices (E1210 and E1211). I am able to write to the E1211 DOs...
167
