hello all,
If hundred versions of rslogix were not enough with rslogix. Rockwell even has logix designer . What is the difference. Does version after 21 can be opened in logix designer. What are the advantages. If I upgrade to latest firmware version on the controller ,will i need to buy logix designer. Is it backward compatible
