Factorytalk view studio - unable to compile the file
gerberz
Jan 2017
Midwest USA
26
So I made some changes to a HMI file 8.0 after making the edits/testing everything appears to be working correctly, but when I try create a runtime file. I get a Unable to compile the file 'C:\Users\Public\Documents.....Attached photo for faults.
Tried that before posting lol? The first time i pressed "yes" and had a error the when i tried to download to a HMI. Tried it again and pressed "yes" again downloaded again. This time it worked with no errors.
Still getting the "unable to compile the file" but if i ignore it everything works fine so IDK.
I usually get a message like this if I've changed a program on another computer that doesn't have an associated image file and it works similar to how you described, ignore and it will compile. I would find those warning messages within your original and compare them after the changes and see if you even need them.
I have not seen that error before but it seems like you have lost a reference from a image or so...
Like others recommended, start with a fresh copy and change one item at a time...
Regards
Regards
I just go and reload the image usually, or even just remove it cause it's usually a local image that is not in the library. Not sure which condition that happens, either when I go from a backup or I've had to restore a runtime application.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
131
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
260
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
683
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
625
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
459
