View ME Gadget Action Indicators
I would use a Multi-State Indicator. Create a self resetting timer. Then in the connection tab Use Timer. ACC / 250. This will give you a 1/4 second flash. Set the Label on each state with your arrows.
State 0
State 1 >
State 2 >>
State 3 >>>
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
117
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
105
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
113
78
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
198
