FTView Alarm banner
coltbean
Nov 2010
Arkansas
I am trying to create an alarm banner that will only show with certain alarms. I have roughly 200 alarms configured that show in the alarm history page but I only want the banner to show when 10 specific alarms are triggered. I then want the ack button to enable a tag in the PLC to let it know how to proceed.
Currently the alarm banner triggers on every alarm and the tag that I have linked to the ack doesn't go high.
Any help is appreciated.
Does your version of PLC software have ALMD? Digital Alarm? Probably need RSLogix 5000 version 16 or higher. If so you can assign the 10 alarms the same class number or name and use it to filter these in the banner.
In the Alarm Setup editor, Message tab, Check the box in the Display Column for Alarms to show and uncheck the box to not show.
Note: from the help file.
In the Alarm Setup editor, Trigger tab, Optional Trigger Connections, Each individual Trigger must have the ACK PLC tag added. If you have 10 individual alarm bits then it must added to all 10. If your using DINT trigger bits then it should only need to be added once. Just make sure you only use 10 bits out of the 32 to isolate the ACK for those Alarms.
Is there a simple way (VBA or macro language) to acknowledge ONLY the most recent alarm? I upgraded recently all the way from RSVIEW 32 7.60 to...
676
Hello all. Is there a way to upload alarm tags at the bit level to my FTView studio? I export them from my PLC thinking I will upload them to...
408
Hi. I'm working on a project with FTView SE 13. What would be the easiest way to beep a sound as a new alarm appear on the banner?
1,069
Hello experts! Can you guide me, please, step by step how to log alarm in my scada project to Ms sql server database. In my project there is some...
1,358
Hi, I am having some issues with FactoryTalk View SE (Local) Alarm and Event server. In my "active" alarm windows all alarms is shown correctly...
968
