nooruh
Dear Friends,
I am using Schneider UNITY Pro XL Version 3.1 software with MODICON 140 CPU 65150. Recently we are facing a problem while going online. It is not going directly to programming mode and says the programming mode is not available and can be connected to monitoring mode. If it is connected to monitoring mode, it show the status and after 5 – 10 minutes one message says PLC reservation is just released and can be connected to programming mode. But if trying to connect to programming mode, again the same message comes and only monitoring mode is available.
Tried power recuycling, downloaded with backyup program, but still the same result. physical communication is normal and in monitoring mode it works and program runs fine, but not in Program mode so unable to edit. I am using CPU ethernet port for communication.
Any similar problems ? or any expert advice please......
Regards....Noorul Hassan.M
