Scada and microsoft excel
use odbc . Create a Dsn and flush your data to it .some simple
SQL codes may help you. Lot of sample codes available in in touch
Use a pivot table in excel to suck the data from the odbc .
Make sure your code for the SQL trigger is perfect .otherwise
You will screw around with microsof products as bill gates people
Are not willing to accept even piped data from outside . Hi hi
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
39
Has anyone ever seen where you have a tag reading from the plc in scada. In this instance it's just a PEC, I set it up on one scada terminal and...
88
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
135
Hello guys, I would need some help. I have installed the aveva plant scada and want to run a project. From the configurator, all are fine, as I...
100
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
84
