Factorytalk ME using goto to send a signal to the plc
powerbob69
Aug 2019
nowhere
is there any way in factorytalk ME to send a signal to the plc with a "goto" button or to link a "goto" and a push button to act at the same time?
I looked into macros and parameters but most of what i found is for SE or too complicated for my level. I only need to send a single impulse when pressing the "goto" button (ON when pushed / OFF when released).
You think it would be easy huh? The only thing easy about Rockwell is deciding to use something else.
You can create a macro for when the display opens. The macro is called from the display. Right click on window, display settings, behavior tab.
Just a thought-
You know you are going to a screen with the goto button, why not monitor the screen number in the PLC and create an event out of it
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
140
Say I take some MODBUS registers and pull into my Logix plc DINT array (sequential). Now, I get a little fancy… using FactoryTalk View SE 13.00...
18
3,191
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,289
Hi, how can i use a defined Tag in HMI Tags (for exampele dintTag ) in VBA code by a display. i am using FactoryTalk SE thanx
2,225
I am trying to open a single display for multiple messages. I understand that I can use parameters to load different messages etc but would like...
1,226
