rhfland
HI – I need to generate variable -10vdc to +10vdc output to a kinetix3 drive from a micro830 PLC. I have a 2080-IF2 and a 2080-OF2. I will have a single LVDT (variable voltage supply) as input to the IF2. I am controlling two drives with the single LVDT input but need to vary the speed of one drive slightly with respect to the other depending on a signal from a limit switch. Where do I start?
